darsben's avatar
darsben
Explorer II
Nov 10, 2013
welding plastic resh water tank
Has anyone had a plastic fresh water tank welded?
was it successful and was it a fairly new or an older tank.
I had a blowout and it cracked the fresh water tank on my 1990 Southwind. I am told it can be welded but some welding forums suggest that an old tank will get brittle and "DRY OUT" and the weld will not last.
Any input appreciated.
If you know of any place in Nashville TN, Jackson MS and then down I55 to I10 to Beaumont that does this, their name would be nice.
I did Google it; I am looking for recommendations for a place to go
  • Repairing polyethylene or polypropylene can be problematic. The age is definitely a factor as the plasticizers tend to disappear either due to chemical bonding or evaporation leaving a brittle material. It can be welded with a heat gun but you have to be very careful about temperature as it will go from tacky to very soft quickly. A backing material to support the soft plastic would assist the procedure. If you need patch material to build up the repair site getting a compatible melt index is close to impossible, unless your able to cut off a piece of excess material elsewhere on the tank. I do not know of a satisfactory glue for use on poly. You might be able to fix using cover plates with 5200 and riveted together.
    I have repaired holes and cracks in plastic kayaks but its ugly work. And additional cracks eventually recur.
    pops
  • More than likely it is ABS. That means you can solvent bond it. If you can find some ABS sheeting, you can use ABS pipe solvent and glue the patch over it. That will be much stronger than welding, and you are much less likely to get it too hot and damage the molecular structure.
    I have welded an ABS tank, but I was using an ultrasonic welder, which allowed me to press the rod into the crack. That worked very well, but I had a lot of control of what I was doing, much more accurate than a hot air welder.
  • Harbor freight tools had a plastic welding kit I have always wanted to get one, have not had the need yet I hear they work well I have only seen pvc welded with it though. good luck
  • I have never done business in the area you are in, but you want to get on Thomas net. The companies you want do not generally do business with the general public. So, they won't have websites or yellow pages ads.
    The tank is probably polyethylene and it can be welded if it has not been in the sun.
    Matt
