tropical36
Feb 16, 2016Explorer II
revrick3 wrote:
Our new to us 2003 Newmar Mountain Aire came to us with a almost new set of Westlake CR976A tires. Size is 255/70 R22.5. Only have about 2,000 miles and only about year and a half old. I am settting up our home and have it loaded for our upcoming travels and getting ready to weigh it on all four corners for air pressure settings. Now I found a problem. I have scoured the internet and cant find a chart for this tire anywhere for weight and tire pressures. I have looked for hours. I found goodyear, Michelin etc and others but nothing on Westlake. Can anyone help me. Can I use the weight chart of other manufacturers if the size, rating are the same? I am unsure and don't want a mistake with this. Thanks in advance. Learned so much on the forums.
Any chart should do and as long as to stick to the same rating....G, H...etc. You shouldn't be too critical anyway and if you weigh each axle, go by that and if you then add 10 - 15psi for all the variables, you should be good to go. Works for me and have been doing just that for years now.
38,777 PostsLatest Activity: Jun 28, 2025
