timmac wrote:
Gjac wrote:
crasster wrote:
Most with Ford & Chevy Chassis seem to really think they handle well. Drive both and see which you like is probably the best advice I can give.
The Ford in particular I have not heard any complaints on the handling.
I guess that is why I asked the question because I have heard more complaints on here about the Ford over the WH. I am currently looking at a 22k lb Ford chassis and see a lot of mods folks on here talk about like the CHF (Cheap handing fix) which most report really helps the ride. I would rather not start adding track bars and such to get a decent ride.
The reason you have heard of more complaints on the Ford chassis is because there is more of them on the road, they all need some improvement to make it ride better, as to noise I don't know about that, I had a 2002 Flair with the 8.1 on a P-32 chassis and was more nosier than my current 08 Bounder on a Ford chassis, I also sound proofed the dog house and now its even more quiet.
Ford did lots of upgrades 2006 and newer with the chassis, motor and trans.
Pick the motorhome by the layout 1st chassis 2nd than make chassis improvements to make it ride better.
. I noticed that the newer Fords were much quieter than the older ones I tested. The fist Ford I tested I though the engine was going to blowin second gear. My old 454 was much quieter. It reached max torque at 1800 rpms , also because I put an extra layer of insulation. Did you do the so called CHF on yours?
