Desert_Captain
Sep 06, 2021Explorer III
A few more factors to consider... The larger the Class C the less, sometimes a lot less, CCC you will get. Options like slides and levelers draw heavily from the preexisting CCC. My 24' E-350 has over 3,000# and we often use most of that. The venerable E-450's usually have around 2,000# +/- which is fine for most folks. If you find one with 1,000# or less "Run Forrest run!" as you will quickly exceed it.
As noted above watch your rear axle weights as they are often exceeded and creatively load, which can mitigate somewhat the CCC/rear axle shortcomings of the larger C's. If you can't run with a full water tank {assuming black and gray ere empty} without exceeding your CCC you probably bought the wrong coach.
As always... Opinions and YMMV
:C
:C
38,707 PostsLatest Activity: Feb 18, 2025
