gsf35099's avatar
gsf35099
What Alison tranny do I have??
Can anyone tell me the best and easiest way to determine what Alison tranny I have?
Freightliner XC chassis with 300 Cummins, 5 speed Alison tranny ( D, N, R, & up/dn arrows) on control panel. 2005. Manual does tell which of the 2000, 2100, or 2500 I have. Any idea where the serial number is? Alison website would then give me details.
Thanks.
  • With the push-button shifter you have a 3000 series. It is a full fly by wire system.
    2000 series have a T bar type shifter with a mechanical pull cable down to a lever on the lower left side of the transmission.
    ID plate is on the right side of the transmission.
  • There should be a plate on the trans, side, front right or left. About 2x3" with info
  • Try looking inside the bedroom closet for the several build sheets; especially the one with the large FREIGHTLINER logo on it. It tells which tranny is in the drivetrain.
    2007 Mandolay Valencia 36A
    Freightliner, Cummins ISB, Allison 2500
  • http://freightlinerchassis.com/RV-Chassis/rv-chassis-article/menu-id-150.html
    This may help.
  • A brochure for that model says it's a Allison MH-2000 - 5 Speed.
    The brochure is here.
