tenbear
Aug 03, 2014Explorer
Bordercollie wrote:
I have never been sure whether RV generator starter is connected to the house battery or chassis battery. If I shut off aux battery disconnect switch, and try to start generator, that should show whether generator is connected to house battery(s)or chassis battery shouldn't it?
BTW, I have noticed that generator will usually start using the start switch on generator itself, when it won't start from the switch at power panel.
It depends on how the genny is wired. Mine is wired directly to the battery so the OEM battery disconnect will not affect the genny. If you have a battery disconnect switch right on the battery, that will do as you say.
