- bobpieExplorerI checked out my 5 year old Michelin 245/19.5 size tires and noticed that the front driver side tire has sidewall check cracking.
Much to my surprise?
I took a picture and went back to the tire store.
They said call Michelin. I haven't done this as of yet. but,
3rd set of tires on my coach.
always a Goodyear man, but they priced themselves out of my budget.
I always cover the tires and park them on deck material Trex pads
This to me is totally unacceptable
the tires that I got rid of were in much better shape than this POS tire. the tires have a 2514 date code on them.
The owner of the tire store made a comment as soon as I said sidewall cracking. Are they Michelin tires? Like they expect them to do this.
Totally Bull **** to me.
I hope none of you have these POS tires on your coach.
FYI
Wish me luck in getting this issue resolved - RayChezExplorer
dcbrewer wrote:
Changed motor oil, and filter.
Greased all zerks.
new chassis battery.
Checked and topped house batteries.
Changed transmission fluid to transend, going do a 200 mile trip and change it again.
Changed air filter.
Why change the transmission fluid at 200 miles? Seems like a waste of money. - dcbrewerExplorerChanged motor oil, and filter.
Greased all zerks.
Changed air filter. - RayChezExplorerWOW! Had not posted in this forum in a long time, but here we go.
I had a bad ignition switch so I decided to buy the switch at Napa and tackle it myself. I got the Freight liner switch through a cross reference from another manufacturer because they told me that the switch was no where in the USA. But they told me they had the exact switch by Napa. So instead of paying Sixty dollars on the internet I got it for thirty two through Napa.
So I was not sure how I was going to pull the part where the tumblers were caged in, so I referred to You Tube and I found one on how to replace the switch on a Fore Travel coach which looked exactly like the one on my coach. It told me to turn the key all the way to the left and get a paper clip and push into a little hole next to where you insert the key and believe it, it come right out. Unscrew the bezel and then just unplug the harness from the back of the switch, put it back together and your done. It probably would have cost me a couple of hundred dollars if I had taken it in to a RV shop. So I saved a couple of hundred at least. Turned the key on and the monster come alive right away. - wa8yxmExplorer IIIWell I had a lunchon invite so when I got home I hooked the towed up because the computer for reservations says this is a 25 foot site. I backed a 38 foot motor home ontto it (with room to spare) and then went back to the road and pulled the car in in front of the MH with room for another and then some.. Today when I got home. I backed in past the MH and hooked up so I'll be faster to split in the AM... NOTE. the comptuer said 35 foot. The care is about 28 foot the motor home 38 and I had room for at least 3 cars (only two allowed) on site more if I parked 2 of 'em beside the RV.
- TrackrigExplorer II1. Changed the outside light to an LED light with several different brightnesses
2. Got it washed at Blue Beacon
3. Changed out a storage latch that broke
4. Got a "blind" lady to adjust the tension on the day-night shades
5. Got on top to take measurements for solar panels. I can fit at least six 190W panels if not eight of them.
6. Finished changing out the tail lights and cyclops light to LED bulbs. I changed out one side but not the other side last trip to see what the difference was. The LED tail lights are brighter.
7. Applied Aerospace 303 to the tires
8. Installed an LED bulb in the light under the microwave. It took us a couple of years to find the right one.
9. Took several naps..........
10. Installed the light bar on the Jeep - does that count for a half point?
Bill - Bill_SatelliteExplorer IIA thread that comes back to life after 16 months!
- Rich_PanganibanExplorerTook the MH to Costco and filled it up for a trip heading to the PNW in 2 weeks!
D.E.Bishop wrote:
Well one of my levelers has been very slow to store and frequently given a jack down alarm so I bought new springs and installed them on the troublesome rear jacks. Not to bad a job, followed a You Tube video on doing it. I came up with a short cut and was happy when it all went well. I'll be changing the fronts next week when they arrive in the mail.
So, did the new springs improve the jack retraction?
Bill - D_E_BishopExplorerI almost started a new thread about working on my class a today. Finally found this old one. By the way when should we start a new one?
Then I changed my battery disconnect relay. Not a difficult job at all. I can hear the relay latch fall out now, couldn't and often it didn't disengage. I now have proper charge voltages, maybe from removing all three batteries and cleaning the batt box and all connections. Charges at much higher voltage too.
Now I can get my genny reinstalled tomorrow and we'll be ready for "Q" next month.
38,763 PostsLatest Activity: Dec 13, 2025
