- turbojimmyExplorer
Canadian Rainbirds wrote:
The reason to fill the fuel tank is to minimize the air space in the tank. Changing temperatures over winter will result in water condensation in the tank. Large air space = equals water in fuel. :E
Yep. It was probably about 1/2 full, which I know is not ideal. The gauge doesn't work so I'm always guessing how much is in it anyway. I keep a log with a conservative MPG estimate, which seems to work. Thankfully I've never been surprised by accidentally running out, but have been surprised at how much more than I calculated is left in the tank from fill-to-fill. - RayChezExplorerLast week I removed the King dome 7200 because all of a sudden it stopped communicating with the receiver for Direct TV. King dome tech said that I needed to replace it because of new technology.
So I purchased through Amazon a new KD 3000b on motion satellite antenna. It was fairly easy to install because I could use the same type wiring that was already on the coach from the previous antenna. I believe it took about an hour to remove the old caulking remove and replace the dome. Recaulked it and hooked it up.
Worked right away.
So now I have the dome that I removed and I am not sure if they can be recycled or what. Seems like quit a waste to just throw it away, but if they can not be repaired, I guess I will just dump it on a dumpster. - Canadian_RainbiExplorer
turbojimmy wrote:
mike brez wrote:
turbojimmy wrote:
I pulled the old Allegro out of its hibernation spot and into the driveway. Put the fridge on propane to make sure it works in preparation for dry camping at the Pocono Raceway in a few weeks. For some reason the fridge fired up immediately and stayed lit. I usually have to fight with the thing, turning it on and of literally dozens of times before it will stay lit. And then the ignitor keeps clicking for hours. This time I flicked the switch, it lit and that was it. It's still lit this morning. And the ignitor stopped as soon as it lit. Go figure.
I need to find a coolant leak somewhere. It puked a bunch of antifreeze out the right front somewhere and the overflow tank is dry. Also installing a tire pressure monitoring system today. If I'm feeling really ambitious I'll put some fuel and propane in it today. I'm not sure the campground where I fill the propane is open today, though.
While in hibernation it's better to store it with a full fuel tank.
Hope the coolant leak is a easy fix. My old class C use to have a small cold drip but was ok when warmed up.
Yes I should have stored it full but I got lazy and didn't stop on the way home from the season's final trip to top it off. I probably put about 30 gallons in it over the winter 5 gallons at a time to keep the fuel level high enough to run the generator.
The coolant thing is a mystery. Last time I had it running in the driveway it left a puddle of coolant. I topped it off today and let it get up to operating temp. Nothing obvious leaking.
I replaced the "vintage" wallpaper-covered fridge door with chalkboard. Going to do the freezer today too. I need to pick up another piece of chalkboard. I'd post a pic but Photobucket has become completely unusable because of the ads. Pages won't load. I need to find another photo hosting site (open to suggestions).
The reason to fill the fuel tank is to minimize the air space in the tank. Changing temperatures over winter will result in water condensation in the tank. Large air space = equals water in fuel. :E - Bill_SatelliteExplorer IIWell, that didn't last long. The same night I posted above we discovered that our Cruise-Air A/C unit for the bedroom was dead. That's a more typical trip for us.
- turbojimmyExplorerMade some progress over the weekend, but not as much as I had hoped. Time to put it back in its parking spot. It's tough to maneuver without a spotter, but I got it in there. Coming back out next weekend, but I needed the room in the driveway.
https://youtu.be/5c-46cP8dkc - Bill_SatelliteExplorer III did something very special recently. Today, I finished a 1000+ mile trip from Houston, TX to Thornton, CO without ANY issues! A very special trip!
I replaced the "vintage" wallpaper-covered fridge door with chalkboard. Going to do the freezer today too. I need to pick up another piece of chalkboard. I'd post a pic but Photobucket has become completely unusable because of the ads. Pages won't load. I need to find another photo hosting site (open to suggestions). - mike_brezExplorer
Hope the coolant leak is a easy fix. My old class C use to have a small cold drip but was ok when warmed up. - turbojimmyExplorerI pulled the old Allegro out of its hibernation spot and into the driveway. Put the fridge on propane to make sure it works in preparation for dry camping at the Pocono Raceway in a few weeks. For some reason the fridge fired up immediately and stayed lit. I usually have to fight with the thing, turning it on and of literally dozens of times before it will stay lit. And then the ignitor keeps clicking for hours. This time I flicked the switch, it lit and that was it. It's still lit this morning. And the ignitor stopped as soon as it lit. Go figure.
I need to find a coolant leak somewhere. It puked a bunch of antifreeze out the right front somewhere and the overflow tank is dry. Also installing a tire pressure monitoring system today. If I'm feeling really ambitious I'll put some fuel and propane in it today. I'm not sure the campground where I fill the propane is open today, though. - GreyghostExplorerRemoved the drop receiver from my tow setup. The Alaska Highway from Haines Junction to TOK and the TOK cutoff to Valdez bent it. Really really bad frost heaves and we kept it under 35 whenever we got to the bad roads. Other that that, a great trip.
38,764 PostsLatest Activity: Dec 23, 2025
