- WanderlostNomad IIDrained the water lines, then blew compressed air through to clear. Added antifreeze to drain traps. Actually supposed to reach 30 here Monday night.
- vscogginExploreri
- Jim_NinaExplorerI'll try to keep this short.
We attended the FMCA ralley in Indianapolis, while there wife became ill. So here it is Dec, wife is on the mend after two major surgeries.
Last month I found time to winterrize the MH. Today got wheel covers on. Been an interesting few months.
Thank you God for looking after us. - HudsonerExplorerInstalled a 20 Amp 12 V marine type outlet in the back of the MH.
- Super_Guy_78ExplorerClean off rubber roof, wash the RV then gave it another coat of Red Max,( that 7 coat now been two years when I put the first coat on) Boy it look good. Then clean out all basement storage areas, things I have not used in years are gone, more room and less weight, ready to go to Flordia now.
- dgcarverExplorerMaybe they just wanted to make sure you could find it!
- Jack_KayExplorerTook it to the Ford dealer and had the oil changed. They did the air filter as well since we had been in a dust storm in New Mexico last month. I asked them to look at the brakes because we had a bit of Brake fade coming down into Bakersfield and they seemed hotter than they should have been. They looked and said the pads were good and showed no signs of overheating. Since that happened we have driven 500 miles, (flat ground) and have not had any brake issues.
Here's the problem... when I dropped off my rig it was in the service department's driveway behind a tour bus. When I came back to pick it up, it was sitting right where I left it! I checked the dip-stick and the oil looks as though it was changed. Could they have changed it where it sat and checked the brakes too? Strange... - RCtimeExplorer
toomoxy wrote:
Just got my RV back from the Trailer place and had:
1. water pump was surging - they found loose wires and fixed it.
2. Had them fix the under couch and under bench seat doors that kept popping open
3. had them install PVC sewer hose holder under the RV
4. had them wash and wax the unit..
5. they checked and applied roof sealant
6. fixed a leak I had on the slide out
7. Cleaned and unclogged my grey water plumbing (smell kept happening)
8. Installed a new Coleman Mach 3 AC unit in front
9. rerouted my generator exhaust from under my slide out to infront and installed a Genturi system
Grand total of $2500.00
I would like to find a dinnette table to replace mine and one with extension if possible. - RCtimeExplorer
great post
I would like to find a dinnette table to replace mine and one with extension if possible. - toomoxyExplorerJust got my RV back from the Trailer place and had:
38,782 PostsLatest Activity: Sep 02, 2026
