More work in my preparation for heading out to the RV.net B10 Rally next week.
My latest project today was to modify our table. we started out with two tables as standard that came with the B but decided to only carry one since we seldom if ever had two tables out at the same time. The table is a rectangular table that centers over a removable post.
Here is the original setup at our front cab seats turned around. It worked fairly well for two people but had its drawbacks that I will explain.
This is the original setup with one table in place at the back sofa. The idea is we would each have a table in the back if desired and there would be room to squeeze in and sit down between the two.
With the unused table I offset the post receptor 4 inches. It is still stable in this unbalanced position and gives us some flexibility. In the front I can now slip into the driver's seat without first having to slide in from the passenger seat side. I can also open the armoire door now with the table in place. Finally, it actually is in a better position for using it as a computer desk for both seats as you can turn it centered to the seat with the edge closer to you..
Here is the unbalanced setup at the front.
In the back we can share the one table easier. It too brings the edge of the table closer for computer work when you twist it around.
I had tried putting a post receptor right in the center but found it interfered with putting and pulling stored stuff under the sofa, so I removed it. After that experiment I decided to try this unbalanced approach. If we decide to go back, the holes are still there in the original position or I can use the unused table.
