- SRTExplorer
tenbear wrote:
Put the finishing touches on my home made generator exhaust stack (Genturi) and put it on the MH for a test. Ran the generator with the AC on full for almost an hour and the stack got only warm, nowhere near hot enough to cause a burn. Very happy with it. I'll use it at the Rally in a few weeks, make my neighbors happy.
Congratulations! Wish more people would do the same. Get tired of smelling the fumes. - tenbearExplorerPut the finishing touches on my home made generator exhaust stack (Genturi) and put it on the MH for a test. Ran the generator with the AC on full for almost an hour and the stack got only warm, nowhere near hot enough to cause a burn. Very happy with it. I'll use it at the Rally in a few weeks, make my neighbors happy.
- woodworker414ExplorerCongrats on the new purchase. I am sure you will have many great memory and make lots of great new friends using the C. Have loads of fun.
Bill - ghsebldrExplorerBought it. My first Class C. 2004 Minnie 32g. woo hoo
- tenbearExplorerReplaced the connectors on the wiring between the MH and the toad.
- Navy_SmokerExplorerWashed it, waxed it and filled it with gas for our trip to the beach next week. Also installed a Scangauge II so that I can monitor RPM and transmission temperature.
- Roach_CoachExplorerThis is my first post as a new member on this forum. Also new to RVing. Bought a used (1993) Four Winds Motorhome a month ago and have browsed this forum many times for info. The way things are going, I could post something on this topic every day!
Today I replaced the chassis battery. It was dead just as we were about to leave our campsite this weekend. Thankfully, I got a jump and it started right up!
Also today, I found a bad splice in the wire under the dash that is the lead for what I think is the battery isolator solenoid. Had the solenoid worked as it should have, I'm assuming I could have started with the dead battery using a boost from the coach batteries.
Unfortunately, this coach was used and it didn't come with a whole lot of information, so I'm in the process of drawing my own schematics. - taylorgsoExplorerInstalled Toad-Charge System on Forest River Solera and 2007 Mazda3. Not a difficult install except for trying to crawl under the coach. Don't have leveling jacks, so drove the coach up onto leveling blocks and raised one side. Found out I need to lose a few more pounds if I want to slink around under the coach.
I use magnetic lights on the toad. Power/signal cord is installed permanently under carpet into front of engine compartment. My next project is to install a quick disconnect in the trunk area so I can remove the lights during off season without having to remove the power/signal cord.
I like this arrangement. With the Toad-Charge system I'm able to leave the toad's parking lights on while underway. I use a drop in brake that activates the toad's brake lights. So, while underway I have 4 taillights on all the time, and 5 brake lights when braking. I like the extra visibility with this system. - HandbasketExplorerIn the past two days, I have replaced the old Elixir ELX30 'battery boiler' converter with a new WFCO 8740, and all 14 of the old roof clearance light lenses with new ones.
The Elixir gave up the smoke at 7.5 years. Only issue with the replacement was having to sit cross-legged in a tight aisle for about 6 hours, and having to cut a little bigger hole. Had to change the wiring very little.
The new clearance light lenses were a really cheap way of freshening up the appearance of a rig that's lived outside for its whole life. I think they were $0.64 each. The old ones weren't just dirty inside, they'd turned slightly cloudy. Even parked in the daylight, the new ones sparkle by comparison.
Jim, "Make three consecutive correct guesses, and you've suddenly established a reputation as an expert." - pianotunaNomad IIIHi,
Fixed the leads to my 300 watt inverter so that I can use it when boondocking to save energy vs the 2500 watt unit. So far I'm just running it off the television outlet. I think I should get some thicker wire
38,769 PostsLatest Activity: Mar 31, 2026
