- Gunner45ExplorerMade reservations for our first weekend getaway of 2014 - can't wait for February!!
Dori - DaHoseExplorerInstalled new magnets to hold the screen door against the outer door, fixed the latch of the inside sliding bathroom screen (now its magnetic) and finished/tested my new electric water heater conversion.
Jose - SpryghtExplorerSigned all the paperwork and spent 3 hours transferring everything from the old TT into the C. Definitely time to do some culling.
Amy - Gunner45ExplorerToday dh put the new flat screen in! We are also planning our first weekend getaway for the year, a February campout!
Dori - DaHoseExplorerToday I finished up my electric upgrade for my water heater. The element is small and replaces the drain valve. It's only a 425 Watt element but it gets the water hot enough. When I was putting it all together, I saw that the tank has two large bosses for anode rods. Looks like I could replace one of the anodes with a thread in element and upgrade to 1500 Watts for $20. Either way, adding on the electric to your propane only heater is a good way to save gas and take advantage of the shore power at a camp site.
Jose - ericsmith32Explorer
Never 2 late wrote:
ericsmith32 wrote:
Got the TV mounted finally.. such a pain to break it down every time. Still need get the wire molding and run the wires and the switch for the amplifier. Not sure if I should figure something out for support going down the road.
Not knowing the whole story I would say YES. Can't be too careful with speeds at 50 MPH and a bump.
Think I had a idea for straps. Technically it's held to the cabinet by four grade 8 bolts and 3 bolts from the base to the arm it almost pull the TV or cabinet a part first. - Never_2_lateExplorer
Not knowing the whole story I would say YES. Can't be too careful with speeds at 50 MPH and a bump. - ericsmith32Explorer
Got the TV mounted finally.. such a pain to break it down every time. Still need get the wire molding and run the wires and the switch for the amplifier. Not sure if I should figure something out for support going down the road. - crawfordExplorerI think some got there facts wrong when the V10 came in 98 is was called E Superduty because at the time it was a cross between a E350 and E450 frame of a E450 suspension front E350. You will see when you buy parts and yet its got the same GVW as 450
- pianotunaNomad IIIHi Harvard,
Thanks!
38,769 PostsLatest Activity: Mar 29, 2026
