- tracyb-ohExplorertook the cover off, drained the pink stuff out of the waterlines, replaced two missing marker lights, fixed the leaking water heater,opened it up and aired it out. Lets Go Camping!
- magik235ExplorerI updated my laptop computer so I can take it on the road. I removed the spring loaded plastic wedges attached to the cab doors. I think they were some sort of anti-rattle device that did not work. I adjusted the door hinges and repositioned the latch posts to eliminate the door rattles. I installed an adjustable cup holder that I found in the RV on the doghouse panel so I can use large size cups for my coffee.
- thebeach300Explorerdrained anti freeze and ran the water pump having a problem thou when i shut the water off and the pump goes to shut off it like something sticks a few times and it dimmed the one light i had on then shuts off.don't know might have to buy another on.
- oldtrucker63Explorer
magik235 wrote:
Your Welcome, With today's gas prices every mile counts for sure.
Today I updated the map on my GPS. Then I downloaded a map program from Garmin and manually planned out 2 routes from Merrill, WI to Phoenix, AZ. Thank you Oldtrucker63 for the information. I intend to map out additional routes to determine which best meets my needs. - ABBY-GIBBSExplorerI installed a 2nd fire extinguisher inside in the rear next to the bed and also installed a 2nd CO detector up front over the genny compartment
- magik235ExplorerToday I updated the map on my GPS. Then I downloaded a map program from Garmin and manually planned out 2 routes from Merrill, WI to Phoenix, AZ. Thank you Oldtrucker63 for the information. I intend to map out additional routes to determine which best meets my needs.
TreeSeeker wrote:
Yelp it has all that and it will not rout you up Rt 33 from Knoxville going to Harlan Ky, It will rout you up I81 to 25 E and that is not the rout to take, And it has been tested all across the USA.
Oldtrucker63,
My GPS has options; shortest route, route using the least gas, highways only route. Are you sure your's doesn't have these? - TreeSeekerExplorerOldtrucker63,
My GPS has options; shortest route, route using the least gas, highways only route. Are you sure your's doesn't have these? - oldtrucker63Explorer
magik235 wrote:
Check your Map along with the GPS, For shortest rout's They are junk.
I bought a TV and GPS for it. - mowermechExplorer IIReplaced the CO detector.
38,773 PostsLatest Activity: Apr 22, 2026
