- Navy_SmokerExplorerWashed and waxed the Mini for the first time. Since I didn't know when the previous owner last waxed it, I scrubbed it with Barkeepers Friend Liquid followed by a regular wash and then waxed it. It looks sharp.
- pianotunaNomad IIIHi,
I added a current tap and thermo cube. I plugged a 40 watt bulb into the thermo cube.
- mowermechExplorer IIA couple days ago, I emptied all the "stuff" (how DID we get all that in there?) out of the Tioga 29H, and traded it in on a Southwind 32V Class A.
Now I have to put all that "stuff" in the Southwind! - magik235ExplorerI scraped the old caulk off the roof rails. Tomorrow I will apply Eternabond roof tape to them.
I added a surge suppressor in the fridge compartment. - trnflaExplorerHad the front flexible brake lines replaced after the left front would stick.
- Michigander2005ExplorerSpent some time putting interior wood screws back in with epoxy glue on threads ;)
- magik235ExplorerI removed the roof rack. I scrapped off all the old putty, cleaned the area with Scrubbing Bubbles, then acetone, applied Marine Goop to the holes and covered it with Eternabond roof tape.
- ReplantExplorerFound out why my HWH levelers haven't been working. Someone hooked the power cable up to the house battery instead of the chassis battery.:R Early in the long rehab process the ignition wire to the solenoid battery isolator was knocked loose and that's why no power was going to the control panel. Now I have to clean mud and rust off the jacks, check the oil and lube the rollers, etc. and of course re-wire the isolator.
Next on the list is fixing the cruise control which the PO didn't get repaired. :(
Took it for a ride yesterday and the completely replaced brake system is working great. Now I'm going out to put on the S/S wheel simulators. - magik235ExplorerMy steering wheel dimmer switch was acting up so I replaced it with a floor mounted switch. I took the dash apart to replace the high beam bulb.
38,770 PostsLatest Activity: Apr 12, 2026
