- MaddawgsExplorerWashed exterior
Todd - magik235ExplorerBought oil, oil filter, spark plugs, air cleaner and a yellow top Optima battery for the house battery. Now I can work on it tomorrow. I took the power center cover off to determine if I could replace the inoperable fan with a computer fan. I lubricated the door hinges and all the outside compartment twist latches.
- primorvingExplorerReplaced old gold color sliding shower doors with new retractable type by Shub and shower head, in my 2004 Minnie Winnie
- bukhrnNomadFinished packing it, leaving in the morning for the 1st long weekend of the year. :B
- CoachDadExplorerJust dropped off my C at the truck shop this AM for a simple check of the front end alignment (been pulling to the right recently) - to find out its not going to be just a simple alignment, more like two lower ball joints, new calipers, pads and hose to both sides.... ouch!
Other than that, mechanic said everything else is in real good shape... - TreeSeekerExplorer
TMBLSN wrote:
Most states have a maximum vehicle width of 102".
I would guess then that all awnings are in violation of this?
If so, then apparently this law is not enforced. - applegaterExplorerJust got my Alcoa alloy wheels installed.
- cal47ExplorerJust added a set of Bigfoot EZE Levelers.
- adamroofExplorerThanks oldtrucker! That validates me a little! The one wire that's looped up to the bracket is a ground I ran a second wire out for, and the dangling wire still needs the pl259 connector that I'm learning how to crimp and solder. I tested the ground to the negative battery terminal for continuity?? and got 0.000 so my frame point I found under a kick panel was good. Hopefully. I haven't hooked up the radio yet, maybe this weekend I'll get it all together.
- oldtrucker63Explorer
adamroof wrote:
You will need to run a ground wire to that bracket or you will not ever get the standing wave out of the radio.
Added Shelving
Increased storage room!
Started the CB Antenna wiring and mounting
(still need to paint bracket and finish heat shrink and will probably return antenna for a white one)
