- Navy_SmokerExplorerFigured out why the reefer (refridgerator for non Navy folks) wasn't working on gas and fixed it. The problem was corroded contacts on the solenoid controlling the gas valve.
- Roy_LynneExplorer IIWent to the kitchen and stole my chilli powder from the spice cabinet so I wouldn't have to go to the store Its so nice to be able to "shop" in the back yard LOL
Also purchased some new plates, bowls and glasses from a local store as they were 1/2 off, - pianotunaNomad IIIHi,
Drove from Stoney Nakoda Casino to pick up my daughter and her boyfriend.
Taking a break using a Telus data stick and a Mofi router, to check emails.
I'm laying on the couch with an inverter powered fan blowing on me--while cooking supper in an inverter powered slow cooker.
I wonder why I even consider having a generator? - pianotunaNomad IIIHi TreeSeeker,
I added a 2nd battery bank (500 additional amp-hours). I added a 2nd wire from the engine charging circuit to that bank. I can charge one bank while using the other, or I can use and charge both at the same time. I can do the same with the solar charging output.
The two battery banks can be "strapped" together via the heavy duty manual switches for my inverter.
I get about 70 amps maximum from the two charging circuits. The OEM maxes out at about 30 amps and the add on at about 40 amps.
They will also act as a "poor man's boost system". If I turn on the ignition energy will flow from the house battery bank and solar panels into the engine battery.
I chose to have heavy duty solenoids that have 50 amp automatic circuit breakers on them. - TreeSeekerExplorer
Pianotuna wrote:
I have added a second charging circuit--so basically the house batteries remain untouched when I'm driving.
Please expound, what do you mean by a "second charging circuit?" - pianotunaNomad IIIHi blackfyreterv,
I should have mentioned that there are 12 volt slow cookers. They work quite well. - 2doghomeExplorerI think it is time for Rehoppe to have his/her eyes checked:)
I use an inverter. Slow cookers don't draw a lot of power--a 400 watt inverter would be plenty for mine (278 watts measured)
I have added a second charging circuit--so basically the house batteries remain untouched when I'm driving.blackfyreterv wrote:
OK do you run the generator to run the slowcooker or do you use an inverter and if so what size? this sounds like a wonderful idea :D - blackfyretervExplorer
pianotuna wrote:
Hi,
Slow cooked a pork roast and dressing as I trundled through the Mountains from Invermere to Airdrie.
It was so nice to arrive and have dinner ready to eat.
OK do you run the generator to run the slowcooker or do you use an inverter and if so what size? this sounds like a wonderful idea :D - smash0greExplorerpulled off the seal under the cabover to let the water drain out of the front cowling.
here... we... go...
38,782 PostsLatest Activity: Sep 02, 2026
