- klutchdustExplorer IIReplaced the air conditioner screen after washing and adding adhesive to the mesh.Sat inside with the air on for a while as it is 100 here today...
- jaycocreekExplorer IITotal water system cleaning including the water heater which I normally do not do but being new to me,it probably needed it.It isn't that hard to do but time consuming using the bleach clean out and filling/emptying again and again.
I enjoy working on my RV's, even just the little stuff.Ready for the fall and winter camping now! - Navy_SmokerExplorerWashed the residual salt spry off all external surfaces, awning and under-carriage after our trip to the Keys. Tomorrow I will steam clean the carpets and upholstery.
- OldRadiosExplorerWinterized it.
- bob_and_donnaExplorertaking it to the shop on friday to have the roller to the slide out re installed. it came out somehow. update. they found most of the rollers loose. cost 500.00 for all the work. feeling better about using the slide now.
- klutchdustExplorer IIPulled the drawer out underneath the fridge and glued some wood to the existing thin panel. I have located and identified it as the vibration caused by the subwoofer located nearby.
Finished installing TV after the front nose bracket repair. Sealed the rubber gasket that is in-between the nose cone and roof of the cab. Small leak in heavy rains. - ericsmith32ExplorerPulled the front tires off had them balanced and rotated them to the other side. While they were off lubed the calipers pins. Surprisingly they still had a little lube on them.. at 40k everything still looked ok despite no maintenance. Need to do the backs but the setup is a bit different. Probably wait till spring. Never worked on something this heavy.
- crawfordExplorerinstall aver hang brackets works great
- klutchdustExplorer IIJust returned from a 2500 mile trip. Replaced mini blind holdown, removed sub woofer that failed as it vibrates too much on bass. Re-glued some wood panels behind front speakers, removed front tv for
access to nose cone. The bracket broke--again--and it squeals like crazy. Going to use fiberglass this time instead of glues that claim they hold anything.... - eddiemac66ExplorerHad an electrical problem. No 110v at general purpose outlets. I looked all over the rv, scratched my head, finally found a 110v outlet in the bath had cycled off. This is something people never think about. Just needed to share the good news!
