FIRE_UP
Aug 26, 2015Explorer
rdmike wrote:
Thanks scott, i too now know 200% more than I did.
How do I know if I have slackers and if I do, how do you adjust?
rdmike,
Well Sir, your sig or your profile does not say what year your coach is but, based on its model name alone, it's fairly new. And that would just about guaranty that you have AUTOMATIC slack adjusters. I'm no expert, not by any stretch but, been around this stuff for decades and, have learned quite a bit by just being around it. I'd say that, based on all kinds rules and DOT specs and all that, I'd just about bet my house, (and I REALLY like my house) that every air braked motor home chassis made in the last 10-15 years or more, has been outfitted from the factory with automatic slack adjusters.
Now, you ask about how to adjust them. Well, as the name implies, they are BASICALLY self adjusting. But, there's a bit more to it in reality. You see, in order for those self adjusters to ADJUST, there must be enough wear on the shoes, to allow for a certain amount of travel in the brakes against the drums. That means they "wore" a tiny bit.
Now, without getting ultra technical here, it works this way. Those slack adjusters are attached directly from the brake can shaft (also known as the PUSH ROD), to the S-cam mechanism in the operation. As you apply the brakes, the diaphragm in the cans travels out and, therefore pushes on the top of the slack adjuster. That slack adjuster is like a minute hand on a clock. If you push on the top end, you have a ton of leverage on the other end of that minute hand. Well, that's how you get the amount of force, needed to push the brakes against the shoes, understand so far?
Well, the slack adjusters also have another component attached to the same "push rod" coming from the brake cans. (at least some of them do, and some don't) And that separate component is linked to "gear drive mechanisms" inside the slack adjusters. While that other component does absolutely nothing in applying the brakes, it's the part that, internally, MOVES gears, pawls, etc. that actually change the way that "Minute hand" is positioned, in distance, from the face of the brake can. Hope this is making sense so far.
So, if that alternate component travels far enough when you apply the brakes, (meaning the brake shoes have wore just a tiny bit) it, in turn (no pun intended) turns the mechanisms inside the slack adjuster to "ratchet" to the next closest position, to make the "throw" a shorter throw. It's complicated but, easy to understand, once you see how it works.
Now, Ok, here's where it gets sticky, in a sense. You can, MANUALLY adjust them, in two different ways.
First off, if you've NEVER HAD ANY EXPERIENCE IN THIS KIND OF THING, DO NOT TRY IT WITHOUT SUPERVISION FROM SOMEONE WHO HAS IT!!! This is your BRAKES you're messing with, care must be taken when goofing around with them, PERIOD!
It's not hard, or even that technical. It is in fact, just like adjusting the "star" wheel on a regular vehicles brakes, only you do it a bit differently. On one side of the slack adjuster is a small collar with a nut sticking out of it. That collar is spring loaded. It can be pushed in. When it is, that allows the nut, inside it, to be turned. If it's not pushed in, the nut cannot turn.
By turning that nut, ever so slightly, you are essentially doing a manual adjustment of the automatic slack adjuster. Now, the second way of MANUALLY adjusting them is, if there's enough play or, THROW in the brake push rod movement, you have to push on the brake pedal hard enough to allow for the "extra" component to sense that there's TOO MUCH THROW IN THE SYSTEM, and therefor, it will automatically ratchet itself, to DECREASE the throw, on the next application of brakes.
Once that's done, it (the slack adjuster) will remain at that adjustment, for however many amount of miles, until the brakes are worn a tiny bit more, and the system SENSESS it needs another adjustment.
So, you see, all this is being done, without your knowing it. Again, there's a bit more to this than I'm telling here but, that's the basic operation of an AUTOMATIC SLACK ADJUSTER. Hope this helps some. To any of you seasoned vets, aka Techs, Mechanics etc. if you're reading anything here that I'm not saying correctly, PLEASE correct me. Again, I'm not an expert, just old.
Scott
P.S. If you cut and paste the link below in an alternate browser, you'll see an image of a automatic slack adjuster. There are a few out there but, this is a basic image.
http://www.anythingtruck.com/commercial/images/421-AutoSlack.jpg
