ron_dittmer
Sep 17, 2019Explorer III
LokiSukaido wrote:A little oil slick in the coolant is not a problem getting the rig home. But coolant in the oil is a catastrophic failure. The engine oil would look like a cream or tan colored substance.
So, I stopped by the RV, to see if I could get it moved. Turns out, the battery there was just about dead. So, I brought the battery home to check and charge. I also checked what fluids I could. The oil looked alright, but the coolant had a rainbow looking hue to it. And, I think she's out of gas. I'm expecting to need to flush the coolant. But, will it suffice to get her 40 miles home?
Bring 5 gallons of fresh 87 octane gas, a charged battery and also jumper cables. With all fluids topped-off and jumper cables attached to your car while it's idling, with all accessories off in both vehicles, hope for the best when cranking-over. You may have to crank for quite some time before you get a response. But before you begin cranking like crazy, read next.
Your fuel pump is located inside the fuel tank. Before cranking, first turn the ignition to the last click before cranking, wait 10 seconds, then remove the key from the ignition and repeat 10 times. What you are doing is energizing the fuel pump which pumps fuel for less than 10 seconds then stops. You want to pump the gas from the rear fuel tank to the engine before cranking like crazy. Following the process significantly reduces the amount of cranking. If you have someone with you, have them do it so you can lay near the fuel tank and listen for the hummm or buzzz sound of the fuel pump. If you never hear such a sound, your fuel pump might be disabled, either from a blown fuse or locked-up fuel pump. If all fuses are good, then the pump might need a good jolt to get started. Bring a 2 foot long 2x4 for slapping the bottom of the fuel tank. Rest one end of the 2x4 on the bottom of the tank, then pivot/slap the tank, preferably while someone else is energizing the fuel pump. It sounds crazy but it works. It could take 20 or more slaps before the fuel pump jolts enough to wake up. Don't dent the fuel tank. A 1990 tank might be made of steel. Once you get the engine running, don't turn it off until you get home because you might be disabled again, requiring lots more slapping.
