Sully2 wrote:
Ocean Mist wrote:
http://www.countrycoach.com/2015/05/country-coach-allure-for-sale/
I have been doing some reading about their demise, and now trying to get back into the game. The coaches seem solid and well built. They said they don't use the "C" channel but round tubing instead?
There's not much info I found yet, but has anyone had any experience with the company?
And what do you think about the Chassis/drivetrain...?
I own one! A 2000 ...36 ft Allure.
I never saw any "round tubing" in my coach??? And Im impressed with the quality of construction and the people AT CC when I call for info on something or a part should I need one.
This is from Sherry Fanning. A kind woman, that loves Country Coach and is an advocate for the brand. She talks a lot about the chassis. I include the link to her site:
"The Chassis designers went to work to develop a steel structure of unsurpassed strength and durability. Utilizing high strength tubular steel they welded together to create the steel cage (the basement, if you will). They next welded the cage to massive 3” x 8” tubular steel frame rails. With this structure in place, Country Coach could utilize the highest horsepower engines on a chassis that could absorb the sheer power and torque that such big engines generate. This meant they chose not to use C channel steel (imagine tubular steel that is missing its widest side, hence the “C” shape). They could have employed an easier, quicker process of bolting the steel together, rather than fusing the steel with high grade welds… but the didn’t. A fiberglass coach has the roof, walls and floors connected somehow to the chassis. CC engineers had to figure a way to integrate these separate house components with the chassis so that it could be fully integrated for the coach to safely travel the road. Chassis engineers built cross bracing into the steel cage structure, properly spaced openings for storage and other components, evenly distributed weight of components, and designed a laminated floor for the house that fully integrated into the chassis structure. The result was a semi-monocoque design where the house came together with the chassis for a motorhome of superior strength and stability."
http://sherry-c-fanning.blogspot.com/2012/02/normal-0-false-false-false.html
