- mdprinceExplorer
Louseman wrote:
Here is a great webpage that explains the components of an RV mounted
propane tank:
RV Tank Innards
Seeing what is inside, can help you to determine what you are seeing
outside, and how to judge the gauges.
Thanks for posting. Very cool to see !! - xctravelerExplorer
Kayteg1 wrote:
I don't see how the Innard page helps in this topic.
Gauge calibration is just that >>> calibration. You can scale it any way you want.
I have not seen a gauge that would show 80% on tank filled up to capacity. If such thing exist, it was design by idiot.
No offence.
Sorry Keyteg, I have had three coaches with ASME horizontal tanks. On each the gauge ON THE TANK showed/shows 3/4 (approx) when the tank is full and liquid propane is coming out the tank full vent. The idiot lights IN the coach read Full at that point. I have little faith in the on board lights so as soon as it shows less than full I duck outside to verify with the direct read gauge on the tank.
Most other coaches I have looked at seem to have the same set up.
Must be that all the people involved in designing these systems are idiots if you are correct. - Mont_G_JExplorer28 gal = 100%
14 gal = 50% or !/2 on gauge - Kayteg1Explorer III don't see how the Innard page helps in this topic.
No offence. - TinstarExplorerThat RV Tank Innards page is good information.
If you want to know exactly how much is left, go have it filled when the gauge shows 1/2 and see how much it takes to reach full. - LousemanExplorerHere is a great webpage that explains the components of an RV mounted
propane tank:
RV Tank Innards
outside, and how to judge the gauges. - Dutch_12078Explorer III
Kayteg1 wrote:
SDcampowneroperator wrote:
If 75- 80% is full, then when your float gauge shows 3/4, thats full. So. 1/4 on the guage is actually 1/3, 1/2, is 2/3, 3/4, is full.
Your DOT tank capacity is stamped on its welded on plate. Look at it, do the math, know your tank size. .
First time for me to learn that propane distribution is regulated by Department of Transportation.
When I believe there is lot of variations in propane tanks, those that I use for decades on forklifts and residential are marked F-1/2-1/4-E
Would what you are saying apply to them, they would never show "F" when in fact they do each time I fill them up.
Forklift tanks and residential are still exempt and they don't have float fill valves.
The portable LP cylinders typically used on towable RV's, gas grills, etc., must meet the specifications established by the USDOT. The permanently installed LP tanks typically used on motorized RV's meet the specifications established by the ASME. The OPD is not a DOT or ASME requirement, but it is a requirement of NFPA 58, the standard adopted by most/all states in their fire codes. - Kayteg1Explorer II
Forklift tanks and residential are still exempt and they don't have float fill valves. - pianotunaNomad IIIHi,
Not on my RV with a mechanical float gauge. The 80% is marked and 1/2 is marked.IAMICHABOD wrote:
As explained to me by my propane guy,it is 1/2 of the 80%,regardless of size. - SDcampowneroperExplorerIf 75- 80% is full, then when your float gauge shows 3/4, thats full. So. 1/4 on the guage is actually 1/3, 1/2, is 2/3, 3/4, is full.
The capacity expressed in gallons on that plate is its total capacity of gallons(or liters) of water, maximum LPG capacity would be 80% of that water capacity.
This is the most misunderstood topic we deal with at our propane dispensing station. Because of the misunderstanding of readings, many, too many think they are low on propane, because they see a 1/4 reading when actually they have 1/3 or more of tank capacity.
Edit, I meant asme tanks instead of dot. Thanks for the correction.
Asme tanks are mounted tanks on vehicles and stationary for other uses. Dot 'bottles' are portable, in most cases do not have level guages.
Permanently mounted tanks that have float level guages that read as full @ 80% are the effort of my post, to help the many inexperienced understand that the levels they read on it are actually thirds of capacity, not quarters.
Max
38,778 PostsLatest Activity: Jun 07, 2026
