bjbear
Jun 21, 2018Explorer
I have had the TST 507 system since last year and very happy with it. I have 12 sensors, all flow through. I like the flow through ones on the coach and have not noticed any problem with flow, but have only had to top up a couple of tires when I moved from hot Arizona to Cold Canada in April.
What others have said previously is true about the flow throughs on my toad (Jeep wrangler). I should have used the normal caps because the flow through ones extend too far out and are at risk when off roading. So far however, I have just removed them when I stay in one place for awhile. Easy to do. Probably later this year when I am back in the US, I will buy 4 normal caps and use them instead.
