tarnoldExplorerOct 09, 2021What is too hotUsing a tire minder, or any other tire pressure/temp monitor, what is too hot for a temp reading. Not looking for reason, low pressure sunny side or near exhaust etc. just what be considered too hot...Show More
Tom_BarbExplorer IIOct 09, 2021I no longer use a tire monitor system.. I find they are more trouble than they are worth.I use new Michelins, keep the proper inflation pressure, and coat the interior with tire slime.I run 100 PSI and feel each tire at every stop, each tire should feel very close to the same.no system will save you from a catastrophic tire failure, a slow leak will show in heat.there are several tire within a tire systems investigate those options.
Related ContentWhy no hot water?Onan hot hot hotNo flow from hot water tank Nautilus P1 systemhot spotsHot Hot and More Hot
