We Cant Wait wrote:
Doesn't matter what the coach says. Check your registered state laws about brakes on towed vehicles. Most (but not all) states REQUIRE brakes on all towed vehicles if the weight is over 3000lbs. With your car at approx. 2600, AND a tow dolly you'll be pushing the 3000lb aux brake requirements.
A little research will show that the above statement just isn't true. It IS a common misconception, but it isn't true.
While most (if not all) have braking requirements for TRAILERS over a certain weight (often either 1500 lbs. unladen weight or 3000 lbs GVW), in many states the legal definition of a TRAILER does not include a towed motor vehicle.
Many states have braking performance laws that mirror (more or less) the FMVSS regulation. Any "combination of vheicles" must be able to stop in a certain distance (usually 40 or 45 feet) from a certain speed (usually 20 MPH), on a level, hard, dry, clean surface.
I have towed various things over mountain passes with 6% grades, without brakes. It can be done with safety, just be very careful.
VERY careful!!
Some states have both the trailer brake laws and the performance standards.
In my research, I have found one state that specifically addresses towed motor vehicles (North Carolina, 20-124(f)).
There may be others, I just haven't found them.
