ron_dittmer's avatar
ron_dittmer
Explorer II
Aug 21, 2014
What Product To Brush On Rusty Metal, Suggestions Please
The under side (pavement side) of our entry step has surface rust that is not bad yet, not flaking rust, not like barnacles. I'd like to brush on a good long-lasting product that is easy to apply. I have used POR-15 on another vehicle which works great but the multi-step process is more than I want to do here given the small, confined area I will work in. I could brush on a few layers of Rust-OLeum rusty metal primer, thinned out for improved penetration, but wonder if there is a better one-step product that I can by at a local retail store.
Any suggestions?
  • Ivylog's avatar
    Ivylog
    Explorer III
    All of these products use Phosphoric acid so even Coke would work.
  • If you Google for: naval jelly
    You'll find quite a few products. Amazon has ratings.
  • Most rust converters will do the job. Eastwood is good and there is a 3M product. You can find it at auto and marine supply stores. I've used rust converters off an on for over 20 years. Always had good results.
    Be sure to prime and paint after the converter dries otherwise the rust will come back.
  • When I was into classic cars I would use the Eastwood product. It's as simple as brushing off the loose rust then coat with the rust converter, then the final top coat such as Rust-Oleum. This stuff is bulletproof and will last forever.
  • Home Depot lists several 'rust converter' products. A quick google search and I found this product. http://www.eastwood.com/eastwood-rust-converter.html
    I have not used either products. I did use something about 10 years ago, it was supplied by a paint company to my work to try out. As I recall it would have a name like 'rust n a me' and it basically converted the surface rust into a very tough primer that was easy to paint, and a hard surface that accepted paint easy. We used Williams Paint as our supplier, and they probably had a rust seminar one day at lunch and presented a 'new' product for everyone to test out. Over the past 10 years, the company that produced that product could have been bought out, and names change, ect.
    Good luck,
    Fred.
