- FulltimersExplorerI got one of these. Best shower head I have ever had in an RV.
- scbwrExplorer II
Dutch_12078 wrote:
We liked this Camco showerhead so well that we bought one for our NY cottage too. It has a positive shutoff valve instead of a dribble valve, and a selectable spray pattern.
Camco 43712 RV Shower Head with On/Off Switch
X2. We had one in our Minnie trailer, and purchased one for our motorhome right after buying it.
Also, consider what water pressure regulator you use. I got rid of the cheapie unit I had and bought a better and adjustable regulator from amazon and find it helps with water pressure.
adjustable water pressure regulator @ Amazon - PuttinExplorerWe also use the Oxygenics- gives a nice spray even using 50lbs of pressure.
- MrWizardModeratorI also have the camco shower head
And like it - Dutch_12078Explorer IIIWe liked this Camco showerhead so well that we bought one for our NY cottage too. It has a positive shutoff valve instead of a dribble valve, and a selectable spray pattern.
Camco 43712 RV Shower Head with On/Off Switch - Bill_SatelliteExplorer IIMost shower heads at Lowe's or Home Depot will also fit your RV shower head connection. You may not have enough water flow depending upon the water pumps or the campground water pressure (or a combination of both) but they are set to 2.6 GPM (can be drilled out) for a good shower.
- Dick_BExplorerOur Oxygenics may be `low volume' but it doesn't seem like it. I even pinch off the valve at the head most of the time until rinsing.
- Big_KatunaExplorer IIIt’s low volume but we are happy with the Oxygenics.
They have a new model called Fury? Haven’t tried it. - Matt_ColieExplorer IIWhile we do have one of the minimal flow Oxygenics that I use most because we are very seldom at an FHU site, I also carry a real shower head for when we are. It takes just moments to swap.
Matt
38,778 PostsLatest Activity: Jun 07, 2026
