hildrethvi's avatar
hildrethvi
what suspension mods to do first??
There are many suspension/handling mods out there. How to decide which ones to do first - which has the most bang for the buck. Just bought a 1999 33' Holiday Rambler gasser - shocks? sway bars? sumo springs, Bilsteins?? Talking alot of money here and do not want to try to reinvent the wheel - would love suggestions on what worked, what to do first, and what was not spending money on - many thanks
  • Lots of great info - much appreciated. I will find a shop in W. North Carolina to check alignment, balance tires. Have checked tire pressure - (80psi) then we will see how that works out before moving on to the things that cost $$$ - not afraid to spend $$ to get results just do not want to spend money that does not help - Much thanks to al that posted!!
  • List potential changes out by price and if you can do the work yourself rather than taking the coach to a shop. Something like this-
    Coach weight and tire pressure - $10/DIY
    Replace rear sway bar bushings - $50/DIY
    Cheap Handling Fix - $0/DIY
    Wheel balancing - $50/Shop
    Alignment - $150/Shop
    Koni Shocks - $450/Shop
    Safety T Plus - $500/Shop
    Rear Trac Bar - $500/Shop
    Sumo Springs (single axle) - $600/Shop
    Airbags - $600/Shop
    Work thru your list low to high cost making a single change and then drive the coach in as many different road, weather, loading,,, conditions as possible to determine if the coach performs to YOUR satisfaction. The more you drive the better you can assess the change. And by more I mean several hundred if not thousand miles. Something as simple as proper tire pressure, sway bar bushings and an alignment might be all you need to get the coach to perform as you want it too.
    For my coach (2006 F53) the lowest cost changes had the largest effect and the associated bang for the buck. Correct tire pressure, rear bushings and CHF. Probably could have stopped there but couldn't help myself. Koni shocks were next in terms of effect followed by the rear track bar. The airbags didn't do much with regards to ride comfort but they also helped regain axle ride height after loading.
    And somewhat related - Chassis and RV service center labor rates can be high, as in the $100+ an hour range, so expanding your mechanical skills and tool inventory will go a long way towards reducing the overall cost of ownership. Lots of information regarding anything you may want to do on the coach from resealing the roof seams, replacing the fridge to doing a transmission fluid flush. These things are not that difficult to maintain just a bit intimidating for some do to the size and weight but if you can memorize "lefty loosey, righty tighty" you just passed the entry exam to the RV University.
    Good luck.
  • I would start with a wheel alignment and COMPLETE examination to determine what suspension parts are worn before I started looking for add-on parts.
    After the alignment have the coach weighed and set your tire pressure according to your fully LOADED weight.
    Then you should drive it and see if you really need any suspension enhancements.
  • I would start with installation of Koni FSD shocks then install a Davis Tru-Trak bar on front suspension and see how that works for you.
    Koni's are a bit pricey but I found them well worth the cost when I installed them on our coach.
    Best of luck and Safe Travels.....
  • If your HR is on a Ford F53 chassis, the "CHF" (Cheap Handling Fix) would be the first, and least expensive, place to start. A search on the forum will turn up lots of info.
  • Chevy or Ford. Does it have new tires. What is it doing going down the road. Have you weight it the way you would travel. Old tires can make it ride like a wagon on steel wheels.
