My monitor panel thats shows voltage and where you store & read voltage does not light up. I am plugged in to shore power and everything is working fine , what do I check fuses? help
If that is the same monitor panel that also shows tank levels, etc, there is a 12 volt fuse for it which is usually located near your main electrical panel.
