ksg5000
Sep 21, 2018Explorer II
If bad weather is forecasted - I pull up anchor and move. If your stuck then I suggest you pull in the slides, fill up the FW tank (helps stabilize rig and give you survival benefit if things get really nasty), disconnect from shore power , pull in awning, secure anything outside, and talk to your neighbors so you can check up on each other.
