carringb
Nov 02, 2013Explorer
tatest wrote:
The weakest point for the rear end of most C's is tire load capacity, which is predicated on heat generated carrying a particular load at a particular speed and road temperature. Driving slower gives you more margin on load. Driving faster can make a tire "overloaded" even if it is not overloaded according to the numbers on the sidewall.
An alternative would be a wheel and tire upsize, to 17.5 wheels with LR F or G tires. However, those higher load ratings, in that wheel size, usually come with much lower speed ratings than those of the 16" tires used OEM by Ford.
^^^THIS
The axle won't fall apart because its a few pounds heavy. Even grossly overloaded, it would probably only accelerate wear, but it won't fail catastrophically. Springs probably won't break either, its mostly a ride-height and suspension travel issue.
Tire though.... they will fail catastrophically. I'm over 10k on my rear axle when towing heavy and every seat it full. I run 235 tires in the rear (265s front) which gives my 2780 pounds per tire.
365,000 miles so far, so good. I did break the differential carrier once, but that was because I hit a new water bar across a forest road, going about 50 MPH. Jumped the van high enough it would have been a top-hit youtube video, had there been a camera running:o Still made it home though. Didn't even find the problem for about 3-weeks, when my "worn bearing" noise didn't go away after replacing them all.
38,766 PostsLatest Activity: Jan 10, 2026
