JCGibson's avatar
JCGibson
What to Look for When Inspecting a Used DP/Gas Class A
We have been 5th Wheel campers for a few years now and are contemplating going to a Class A. I am wanting to know what to look for when inspecting a Class A DP or Gas unit.
Also, what additional annual/periodic maintenance things should be done to the unit that might be different than a 5th Wheel (obviously drivetrain maintenance)?
Furthermore, what kind of fuel mileage can I expect to get with either a V10 or DP that is loaded with water, fuel and supplies? With my current setup of Dodge 3500 Diesel and 14K 5th Wheel I get about 9-10 MPG depending on terrain.
Thanks in advance.
  • You should look for exactly the same things as in a used 5TH wheel. The appliances, roof, exterior and age of tires. That is the end of your job. The rest should be left to an INDEPENDENT TRUCK REPAIR not an RV dealership. You are looking for a mechanic that does a LOT of truck work. Ask the repair shop how much to check the powertrain, suspension, brakes etc for you and pay them for their time. Make any offer contingent upon the rig passing the repair places inspection. If seller does not cooperate then that is telling also
  • The fuel mileage will depend on weight and and engine size. I would think it's safe to say that you will get a 2-3 more miles per gallon with a diesel of the same weight as a gasser. Generally, the diesel will be heavier anyway.
    Our 40,000 lb., 425 hp Cummins, 2008 Monaco Dynasty has averaged 7.8 mpg over 69,000 miles. Maintenance for us is about once a year with an oil change and generator service. I have the oil changed every 10,000 miles and the genny every 250 hrs. The Aqua-Hot I have done every two years. The front wheel bearing greased every 30,000 miles.
    House batteries lasted 6 yrs, I changed the tires at 57,000 miles that were 6.5 yrs. old. Chassis batteries lasted about 3 yrs., just bought two new ones.
    I have/had things repaired as needed along the way.
    MM.
