RLS7201
Nov 09, 2015Explorer II
While in Phoenix traffic I smelled hypoid rear end grease. The next morning, while in the campground, I pulled the RR hub and replaced the hub seal. O'reilly had the seal and the special socket to remove the hub nuts. Had to scrounge up two 5 gallon buckets. One to sit on and one to rotate the hub and rotor on to. The bucket caught all the grease.
Why all the talk about buying a battery charger when the alternator or belt fails on a MH? The Generator/converter will charge the chassis battery when the engine is running. Think about it. When the engine is running the isolator relay is engaged.
Richard
Richard
38,706 PostsLatest Activity: Dec 02, 2016
