MrWizard
Nov 09, 2015Moderator
not if the relay is energized by the weak chassis battery
and may RV's have weak converters that do not charge well, with very low amps
the 40amp or more converters NOW common, did not use to be common
an RV with a Diode isolator is not going to charge the chassis battery period
the jump start function is only momentary
although with a good converter, a jumper cable between house positive and chassis positive, would do the trick
38,706 PostsLatest Activity: Dec 02, 2016
