wa8yxm
Aug 17, 2015Explorer III
First: No such thing as a "Digital Antenna" only Radio Antennas (Television is a form of radio, does not matter if analog or digital)
And my two favorites are: If your existing Winegard Sensar II or III is in good condition.. #1 Add the Wingman
If it, as they say, has seen better days.. Sensar IV (Comes with wingman)
Of the antennas I've seen tested NOTHING beats a batwing with wingman
Improve on the best by adding the SENSAR PRO inside the RV (this is the power supply for the mast heat booster, a 2nd booster, a scanner, and .. Well read the manual to find out all it can do for you, beats the LED's off Jack's "Sure Lock" device)
I have not seen a lab test on the Razyer but understand one of the options there is both directional and automatic.. Do not know how they pull that off, but if it works.. I'd have to see the lab results to comment farther.
38,782 PostsLatest Activity: Sep 02, 2026
