rgatijnet1
Aug 17, 2015Explorer III
If you have been having signal problems with an antenna that was previously working fine, I would say that your problem is with the coax cable or the connections on either end. Antennas do not wear out but the cable connections do. They let in moisture which eventually causes corrosion. To install a new antenna, without correcting the cable problems, is just a waste of money.
38,782 PostsLatest Activity: Sep 02, 2026
