ander's avatar
ander
whats everyone us for a jack
hi all.
Comming down from Mt lemon monday( 9,157 ft according to the sticker we got) we get to the first stop sign at the bottom and noticed a loud rattling noise as we pulled away..
first though was i had dropped a tail pipe. sounded just like we were dragging tin cans.. we pulled over and quick look showed nothing dragging, just then GF sees smoke comming from the pass side front wheel well. quite a bit of white smoke.
that went from a Hmmm moment to a OH **** real quick. i grabbed the extinguisher and dove under the front end but no fire just white smoke pouring out of the wheel.
brakes and lines seemed fine..could even touch caliper. back to HMMMMM.
i popped the hub cap off and found the problem.
the dust cap had popped off and was rattling around in the hub cap...looks like i smoked the front bearing.
as we sit there wondering about towing options vs changing bearing on side of road at 4pm i see there is still grease in and on the spindle and bearing..no chunks i can see and wheel doesnt rock just that the hub is about 8 million degrees.
anyway...i pull out the 8 ton bottle jack that came with the rig when we bought it, to jack tire up and see how bad bearing really is and of course it doesnt work.( see i got to the thread title :).
in the end we waited an hour then took the back roads slow and easy the 30 miles home. the old girl got us home.
so what is everyone using on there older rigs for a jack?. is an 8ton bottle overkill? 2 ton floor jack not enough? im around 7000lbs last time i went over a scale. havent done a front/ back yet.
all 4 wheels are getting new bearings this weekend... they are probably stock 20 yrs+ now.
thanks.
