- ron_dittmerExplorer IIII did not read through all the replies so maybe much of this is redundant.
I put this together a while ago for people asking the original posting question.
New or used, when shopping for any conventional class-C, the most important consideration is how it is constructed. What construction methods are used to be most affordable, and what methods cost more but are built to hold up much better to the elements and the punishment of a constant earthquake when being driven.
Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
When shopping for a motor home, don't get distracted with what I call "Eye Candy" and/or "Square Footage". You want to pay close attention to how the house is constructed. Water penetration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets in, it is like termites. By the time you realize there is a problem, a lot of damage has already occurred. Mold can also grow inside the walls which then you have a health hazard. My advise focuses on identifying a Reliably Well Sealed motor home.
#1 BEST (Very Expensive, Can Be 1.75 to 2 times the cost of Second Best)
NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, entry door, roof-top vents & a/c unit, storage compartments & maintenance access, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes are limited in size.
#2 SECOND BEST
Common, Affordable, & comes in Many Sizes so this is my main focus
I own an example of this type. My Rig Here manufactured by Phoenix USA.
Made in sections, but assembled in a way that greatly reduces the threat of water. Here are the good things you want to look for.
a) Structural Seams Away From Corners
When a motor home is driven, the house bounces, resonates, shakes, and leans, many thousands of times, representing a series of extended continuous earthquakes. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lower stressed areas.
b) A Seamless Over-The-Van Front Cap
A huge bed above the van’s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven. It is common for seams to split there, most troublesome with age & exposure to the elements. The small front aerodynamic cap of a B+ design eliminates the overhang which eliminates most of the resonation, along with most seam work.
There are a few conventional “C” Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design. Born Free offers a seamless bucket design as seen in This Model. Winnebago's View Here is another fine example. Some manufactures as of late offer a partial bucket design with fewer seams located in less-stressed areas. The Nexus Phantom applies a partial bucket concept. If you plan to accommodate more than 2 people, that extra bed would be extremely important.
c) A Crowned Roof
Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after gaskets & caulk have degraded from age, sun, and change in seasons.
d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
A single sheet of fiberglass that rolls over the right & left sides of the roof, down the wall a few inches. The fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
e) A 5 Sided Rear Wall Cap
This 5 sided back wall moves the seams around to the sides to areas of much less stress.
Potentially Troublesome Construction
Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed. Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example. If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
There are also rare exception like the Lazy Daze which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body. It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
About The Chassis
The most popular is the Ford E-Series with the V10 engine. The Sprinter diesel is a popular alternative to the E350 in the smaller sizes. The GM chassis is not popular, but is a very good choice for the right application. Any of those three brands since 1998 are real good, new or used. If you plan to tow a car or heavy trailer, be aware that the Sprinter is the least powered chassis. People who tow with a Sprinter, take it slower.
If considering a recent “small” class B+/C motor home, here is a comparison between the two main contenders, the Sprinter with the V6 diesel engine and the Ford E350 with the V10 gasoline engine.
Advantages Of The Sprinter With Diesel Engine
- Offers a 35% improvement in fuel economy over the Ford-V10, when both are loaded and driven identically.
- More ergonomic driver compartment with more leg room.
- Comfort continues with a car-like feel & quiet ride.
- A grander view out the windshield
- Made by Mercedes which people are attracted to.
Advantages Of The Ford E350 with V10 Engine
- Given identical motor homes both brand and model, the Ford is around $13,000 MSRP cheaper
- The Ford V10 engine has 50% more horse power and torque
- The Ford E350 chassis handles 1430 pounds more weight.
- The E350 is able to tow a heavier load.
- The E350 rear axle is significantly wider which translates to better stability.
- In most places traveled, gasoline costs less than diesel fuel
- The Sprinter diesel has limited mechanical service shops around North America
- The Sprinter diesel is typically outfitted with a propane generator. Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
- This Next Point Is Debatable But Still Worth Noting....The V6 Sprinter diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions or you are dangerously low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford V10 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Via, View and View Profile. Others like Phoenix USA build their model 2350 and 2400 on both the Sprinter and Ford E350. They will even build it on the heaviest duty E450 upon request for a nominal fee. People who request an E450 for a small motor home, tow heavier things like for example, a multi-horse trailer. You can even special order a E350 & E450 4x4.
There is so much cool stuff offered in recent years, and even more anticipated with the upcoming Ford T-Series chassis. The general public hopes it will become available for the RV industry. It is kind-of like a Sprinter in size and fuel economy, but hopeful to be much more affordable.
The Chevy 3500/4500 Chassis
I do not understand why this chassis is not more popular. It offers more interior comfort than the Ford, but not as much as the Sprinter. It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs. They are also a little better on fuel consumption. One thing to keep in-mind, if you are counting inches to store your rig, the Chevy adds an additional 9" to the front bumper compared to the Ford. I learned that researching rigs that could fit in my 25'-0" deep garage. By default, the Ford gave me 9 more inches to work with. If you examine my motor home in my garage HERE, you will see an extra 9 inches in length might have been detrimental.
Engine Power Ratings of Ford, Sprinter, & Chevy
Ford - 6.8L-V10, 305hp, 420ft
Sprinter Diesel - 3.0L-V6, 188hp, 325ft
Chevy - 6.0L-V8, 323hp, 373ft - gmctoymanExplorerI think a blue one is the best Class C.
- DiploStratExplorer
pianotuna wrote:
Hi Diplo,
What are you using for a stove?
Is Water heating diesel?
What chemistry are the batteries and how large is the battery bank?
Don't want to hijack, but:
-- Stove is a True Induction: True Induction Single
-- Air and water heat is through a Webasto Dual top: Dual Top EVO
-- Batteries are 4x300Ah 6v Lifeline AGM: Big Beasts! - littlemoExplorerBesides the obvious,(fiberglass roof with one piece endcap, no window in cabover, no leaks, chassis choice, etc.) you need to look at space planning, floorplan, how many people you will need sleeping room for, basement storage. You need to go to RV shows with family and just look, look, look to see what works. And get on this forum and read and ask lots of questions.
- BordercollieExplorerStick with a popular brand like Winnebago, they seem to have good after sale warranty service, good overall quality, current features, and technology.
Most brands have pretty much the same Ford or Chevy drive trains and "innards" i.e. appliances, AC units, furnaces,etc. There are differences in roof and cabinetry construction. We have a 2004 Fleetwood Tioga which I think is of average quality . Tiogas are almost identical to Fleetwood Jamborees.
The "Best" Class C's can cost $10K more than average Class C's but they have better resale value, especially if well cared for. Exterior graphics fade and crack with sun damage. If you keep covered or in a garage the new look lasts indefinitely. - pianotunaNomad IIIHi Diplo,
What chemistry are the batteries and how large is the battery bank? - pnicholsExplorer IIIn the rig's photo it appears that it began life as a Tiger model.
It seems that painting it black would turn it into an oven in desert heat. I wonder how that would work out? Probably idling the main engine all day long so as to use cab air to cool the living area? I read once that expedition vehicle designers tend to prefer white or silver as the exterior colors of choice for the best all around camp-anywhere-anytime compromise. - DiploStratExplorerHow well does it all work? Let you know this time next year! :)
The design goal was three days of full service (two adults, three hot meals, two showers, 65F interior temp) without engine start or sun. With 40 gallons of water, and using 150Ah per day, we can do it.
For longer autonomy, you cut back on showers, use a sleeping bag, etc. (I crossed the Sahara on under 20 gallons, so I know how to economize.)
If really out in the weeds, then you simply start the engine while running the stove or microwave, the minimum output of the alternators is 150A, and 30 minutes will recover most meal prep. As a practical matter, your trip into town would accomplish that easily.
The beast was finished in December, so most of our testing has been at or below the freezing mark. Will have to wait for our trip to Overland EXPO to see how things work in more temperate climates.
I would note that the truck has not been connected to shore power since before 12 Feb 2014. Granted, the water was drained and the heat turned off after the last trip, but normal winter sun is enough to bring the batteries to 100% every evening unless the snow is too deep. The biggest variable is heat, when the heater is on, it consumes more battery for the fan and, of course, diesel to heat the water and air. The most urgent needs have been to dump grey water as the tank is only 25 gallons.
The truck does have a shore power cable and a 2800w Magnum Inverter/Charger - the no-shore-power criterium was simply to avoid having to carry a heavy transformer when overseas. In the States we simply ask for a tent space.
But basically, there is no magic, just a lot of solar and a pair of 125A alternators. - pianotunaNomad IIIHi Diplo,
The Ndeke Luka appears to be a (shocked look) truck camper. - pnicholsExplorer IIFred,
I'm curious.
As a hypothetical example ... how does Ndeka Luka drycamp out in the wilds of say, a western Washington state rain forest, in two weeks of solid gray skies, rain every day, with no daytime temperatures higher than around 50 degrees and nights around only the high 30's ... and then just make a too-short-to-recharge-batteries quick run into a small town for food, and then back out to the same campsite to repeat it??
I could do it in our small (and inexpensive) Class C - but would have to replenish the water tank, propane tank, and dump the grey/black tanks after buying groceries in that small town. If needed we could periodically run either of our two generators or idle the V10 to recharge the coach battery bank in any weather. Our range is only 500-550 miles, however.
38,766 PostsLatest Activity: Jan 10, 2026
