- imgoin4itExplorerI did not like the way my Newmar drove when it was new. Had an allignment done and drove totally different and like I thought it should.
- wolfe10ExplorerGood idea to load it as you will be using it, weigh it so you can accurately set tire pressures and THEN have an alignment done. Get a "before and after" print out and have them set caster toward the high end of spec. That will help with tracking.
- The chassis are "aligned" at the factory with no weight. Once the body is added, and, have some water in rig about 1/2 tank, your gear have the rig weighed and then aligned.
38,763 PostsLatest Activity: Dec 28, 2025
