Tom/Barb wrote:
We have the HWH system, hit the on button once, run the jacks down until they touch the ground, hit the on button again, the air will dump. hit the off button.
Standard routine with us, because we do not like our coach way up in the air.
Your HWH system does have a manual mode.
Sorry, you reasoning does NOT make sense. You state you do NOT like your coach way up in the air. But, doing your procedure is exactly what you do NOT want to happen. By lowering(extending) the jacks with Air bags FULL, will level the coach 4 inches HIGHER off the ground. Once the RV is level, you do NOT have to hit the Air dump button. The Air bags will deflate due to the jacks causing the ride height arms to move and auto deflate the bags. There IS a reason that HWH Auto/Computerizes systems DUMP the Bags FIRST, then level. Doug
