Sam_Spade
Jun 22, 2017Explorer
KeepMoovin wrote:
2003 Fleetwood tioga 29V. When I'm on Shore power or generator, all outlets work. When I am on the aux batteries (with inverter on) only a couple outlets have power.
Highly likely that it was done that way on purpose.
Best not to mess with it and just use ONLY the outlets that are hot when running on the inverter. It has a very limited current output, probably, and can't run many things at the same time.
And no probably not an "easy" or "reasonable" way to add an outlet to the inverter. A heavy duty extension cord might work.
What exactly IS it that you want to use that you can't plug into one of the outlets that DOES work off the inverter ??
P.S. And sometime soon you should find out what the capacity of the inverter IS so that you will know what things you can and can't use in those outlets......because they probably are fed by the inverter ALL the time, shore power or no.
