tatest
Jun 22, 2017Explorer II
KeepMoovin wrote:
One more question..well two...Is there a reasonable way to "switch" circuits so I could choose which circuit was used? Or can one outlet be added to the existing circuit?
That depends on the location of the inverter. If near the batteries and AC panel, some rewiring may be reasonable. It the inverter is near the outlet, fed by a long 12 volt run (common on small entertainment inverters) rewiring can be a lot more difficult. Once you move away from the electrical panel, much of the wiring would be run in channels cut in the foam core of your wall panels, not very accessible after the panels are skinned. Sometimes wiring runs go through cabinets, and can be easier to get to.
