eric99
Mar 13, 2015Explorer
Ivylog wrote:
It would help if we knew what's over 5K that you want to tow. If it's a large vehicle that you are going to tow four down you do not need a new hitch. A simple V brace from the receiver to the MH rails is all you need as you do not have any tongue weight. If it's a heavy trailer with more than 500 lbs of tongue weight then a H looking brace may be all that's needed added to your current hitch. Any good welding shop should be able to solve your problem once you tell them what you are trying to do that exceeds the current 5K hitch.
It would be a large vehicle. I can't imagine over 7,000 lbs. Chevy Avalanche weighs in around 6,200. A Suburban can't be much more. I think.
38,705 PostsLatest Activity: Jan 26, 2025
