- Teacher_s_PetExplorerOur Tiffin on a Freightliner XC chassis has a center console up front with two drawers, there is a good sized fuse panel under the lower drawer which must be completely removed for access. We also have panels inside the hatch under the driver's seat , under the refrigerator, and in the rear compartment on the passenger's side are two which are all breakers.
on edit: DW noted I was wrong on the side of the rear compartment breakers, how could that be? :) - RayChezExplorerMost Freightliner fuses are on the first compartment under the drivers side.
- DellnDaveExplorerIt's a Freightliner.
- DellnDaveExplorerWe found it in the console between the driver and passenger there are several fuse box is jammed in there. If used is indeed blown and hopefully we will be able to finish our travels tonight. Thank you for all who helped.
- sch911ExplorerWhat chassis?
- 2oldmanExplorer IIThe best I can find is: " 12v mini breakers under the entry step, or engine firewall behind the passenger headlight."
- DellnDaveExplorerWe have the manual. Does not tell use WHERE fuses are.
- 2oldmanExplorer IICan you google for the owner's manual? I found one.
- cmcdarExplorerHere is a link to another thread on this forum with info regarding fuse possible locations.
Maybe one of the replies will help you.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/15450693/print/true.cfm - DellnDaveExplorerAll other functions work. No fog/hazard lights no head lamps hi or low. Running lights and turn signals work.
38,769 PostsLatest Activity: Mar 31, 2026
