1buda's avatar
1buda
Fuse panel
Been wanting to change out my old glass fuse panel to a spade type fuse panel. What is out there as a replacement?
  • RoyB wrote:
    Was reading some of your previous posts and thought I read you have the Magnetek 6300 Power Distribution panel. If that is what you have then it should be using the ATC type DC fuses...
    These are ATC BLADE TYPE fuses
    When you refered to glass fuses I was thinking of this style fuse
    The ATC Blade fuses is what all the modern Power Distribution Panels uses...
    If this is what you have the PD 9260C 60AMP would have been my choice to use as a replacement converter/charger for the bottom compartment of this Power Distribution Unit.
    Just my thoughts
    Roy Ken
    That's what I have, and that's the converter I just installed. World of difference.
    Just my thoughts
    Roy Ken
    What I did have is a BW series 3200 Model 324oul, which I think they don't make anymore.
    What I do need is the fuse panel like you posted.
  • RoyB's avatar
    RoyB
    Explorer III
    Just my thoughts
    Roy Ken
  • My converter is toast, made back sometime in 1985. I have a Progressiv?e Dynamics on its way. I plan on using the fuse panel off the old one. Thanks Old Biscuit for the link, I will call him tomorrow. He does have fuse panels for sale but take the glass fuses.
  • Check with this place......Best Converter......talk with Randy about what you have and what you want to do.
    Great company....excellent customer service
    LINK
  • What is the make and model of your current DC power distribution panel?
    The same manufactuer may have the same unit or you maybe able to buy direct replacement with blade fuses.
