rgreda's avatar
rgreda
fuse panel
Bought my first TT. 2000 32" hornet by damon. need help locating fuse box/power inverter.thanx.rich
  • rgreda wrote:
    I'm sorry, I meant converter. Got it, below fridge. I assume ac fuse should be there. Thanks guys!
    No AC Fuse........as in 120V AC Voltage. Circuit Breakers in 15A, 20A 30A 50A etc.
    A/C fuse as in for Air Conditioner....that would be a 12V DC Fuse used for thermostat and Air Conditioner Controls
    And Air Conditioner would also have a 120V AC Circuit Breaker 15A for the Fan and Compressor Motors
  • I'm sorry, I meant converter. Got it, below fridge. I assume ac fuse should be there. Thanks guys!
  • Odds are that there ISN'T an 'inverter'.........just a 'converter'
    Open the panel where 120V AC Circuit Breakers are .......DC Fuse Panel should be part of that power panel
    Typically in kitchen area. Will have small slotted opening for fan in cover.
  • You will likely have a panel that looks something like this:
    Press the top center of the door and it should pop open.
    Will have 12v DC fuses, and 120v AC breakers behind the door, the fan grill below is for the CONverter (120V AC to 12V DC/battery charger) Most trailers of this era will not have an INverter (12V DC to 120V AC) unless it was added by someone, and it could be installed just about anywhere.
  • Power inverter should be close to, or the same as, the power converter. Follow the wires.
