1buda
Nov 17, 2013Explorer
Fuse panel
Been wanting to change out my old glass fuse panel to a spade type fuse panel. What is out there as a replacement?
RoyB wrote:
Was reading some of your previous posts and thought I read you have the Magnetek 6300 Power Distribution panel. If that is what you have then it should be using the ATC type DC fuses...
These are ATC BLADE TYPE fuses
When you refered to glass fuses I was thinking of this style fuse
The ATC Blade fuses is what all the modern Power Distribution Panels uses...
If this is what you have the PD 9260C 60AMP would have been my choice to use as a replacement converter/charger for the bottom compartment of this Power Distribution Unit.
Just my thoughts
Roy Ken
