- Golden_HVACExplorer
RoyB wrote:
Here is a neat article from google search with some photos...
HARD START CAPACITOR FOR RV A/C
Roy Ken
If you where to click on the link above, you will see several pictures, including the removal of the 4 screws to open the top of the A/C unit on your roof.
Here is a picture of the two capacitors. The smaller silver one is attached to the indoor fan motor.
The larger silver capacitor is the run capacitor for the compressor.
Good luck,
Fred. - IvylogExplorer IIIThe run capacitor is the smaller of the two but you need to ground out both capacitors before touching the wires. I use a long screwdriver from the sheet metal to the wires on the top of both capacitors.
- RoyBExplorer III
- wolfe10ExplorerOnly accessed from the roof (shroud removed).
38,778 PostsLatest Activity: Jun 06, 2026
