- wa8yxmExplorer IIIYou ask a very good question and there are many answers all but one is likely valid for someone (Raise the bail)
On my RV the valve was in the OUTSIDE fridge access compartment..
As someone else said under the sink.
Open the back access panel it's a louvered panel On Dometic there are slooted retangulary Thingy heads turn 90 degrees and pull out (not sure of No_Colds but think a like method).
Find the water solenoid (obvious device) and follow the line as far as you can. Then look for other access both outside and inside. Odds are it won't be far away. - Blaster_ManExplorerMy shut off is in the water line between the water source and the refer....and is behind a panel under the kitchen sink.
- rk911Exploreryou can just raise the bail to stop ice cubes from being made but that does not shut off the water,
- grldstExplorerI have an older HR Endeavor, my ice maker shut off is in the compartment by the hot water heater.
- craig7hNomad III will say that I have no where near your rig. With that said the shut off to my ice maker is under the kitchen sink. Its a small inline value that you turn to shut water off. I would start your search there.
