rware
Nov 25, 2013Explorer
Where to plug in converter
I have a 2009 Holiday Rambler Admiral 30SFS made by Monaco.
In the rear power hookup compartment there is a converter screwed to the back wall with a small 2 foot power cord and a standard 3 prong 110V connector. Can someone with a similar coach tell me where the converter is plugged into?
The long story. When I got the coach I had solar panels and an inverter added. The inverter also powers the coach battery so the converter was no longer needed. The solar installer said leave it there unplugged, if you ever remove the inverter you can plug the converter back in. Well now I am having problems with my inverter tripping, until I can get that sorted out I wanted to turn of the inverter and plug in the converter so that at least my house battery bank got charged at night.
Here is the problem, I can't find where to plug the inverter in. I have crawled around that compartment with a flash light over and over again, there is no 110V outlet. It is driving me nuts, the converter used to work but where was it plugged in. It had to be within a very short distance of the converter given the power cord length. I could run a 110V line down from the coach, it wouldn't be too hard, but there has to be a 110V outlet there somewhere!!! I am going nuts looking for that thing. :h
Thanks,
Thanks,
