- IvylogExplorer IIIOP, in looking at your blog, I think you need something like this with a Cummins engine:
- themoreweexplorExploreryeah, that's where I first found out about them. THey're the most desirable motors in the school busses. I've kicked around the idea of a school bus conversion, but I want to hit the road sooner than later.
- hone_eagleExplorerCommon in school buses,dead reliable and preferred over the 444
- themoreweexplorExplorerGood point lvylog
- IvylogExplorer IIII've spent way too much time researching used MDT trucks... narrowing it down to crew cab Freightliners. Never saw one with a DT 466 (like I said above.. a good engine) but I did see way too many with a rebuilt Cat 3126/C7 at the 400K-500K miles range. The Cummins 8.3L/ISC would go in the 700K range with 250-300 HP. Most of the Cats at even 210HP did not make it to 500K.
Not sure why you are worrying about longevity as the average MH only gets 5-7K miles/year so in 20 years 100-140K miles, few enough for even a Cat engine to still be going strong. - AndyWExplorerJust me, but when looking at an 20+ year old motor home, the model of engine would be the least of my worries. Maybe if you find two otherwise similar units it would be worth considering to break the tie, but as the primary criteria? There are more important considerations...
- themoreweexplorExplorerthanks Cliff!
- cquinn5Explorer1996 Country Coach 40' came with the D40 (DT466). My neighbor had one. I believe they soon switched to the C series Cummings.
Cliff - themoreweexplorExplorer
moisheh wrote:
there are other considerations like build quality and layout. Finding one with your desired engine but nothing else is not the answer.
Agreed, but it's a starting point. I don't have to have a dt466, but if I can get a list of 4-5 rvs thar came with them, them I can start researching if my other criteria are met. - mike_brezExplorer
moisheh wrote:
There are lots of bargain priced DP's with older engine technology. Have you considered a Bluebird. Lots of nice units under $20,000. But I really don't think you will find a DP with that IH engine. Besides there are other considerations like build quality and layout. Finding one with your desired engine but nothing else is not the answer.
Moisheh
...and the BB will have leaky/smoking 6v or 8v92's
38,706 PostsLatest Activity: Feb 03, 2025
